przez Vince » 8 paź 2010, 15:46
maestrol napisał(a):ok a skad bede wiedzial co oznacza numer np. 95
Polecam tą stronę:
http://codes.rennacs.com/Petrol-Engine/Japanese-Korean/Mazda-Engines.phpjeśli oczywiście znasz angielski
Wyjaśnione krok po kroku jak odczytać błędy i co one oznaczają. Powodzenia!
There are only two things to worry about: either you are well or you are sick. If you are well then there is nothing to worry about. But if you are sick, there are two things to worry about: either you will get well or you will die. If you get well, then there is nothing to worry about. If you die, there are only two things to worry about: either you will go to heaven or to hell. If you go to heaven, there is nothing to worry about. But if you go to hell, you'll be so f...ing busy shaking hands with friends, you won't have time to worry. Why worry!
